Hot Water From Cold Water Pipe!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2011, 02:45 PM   #1
Hot water from cold water pipe!!
Hi guys, answer seems simple but the problem is as soon as I open the hot water tap the warm water come out fine in the sink.
However, the cold water from the mains is not connected to the cold water tap. So as soon as I close the hot water tap off and then turn on the cold water tap hot water comes out of the unconnected cold water pipe under the sink
I don't understand the logic. Is there a problem with tap?? Not sure but would really appreciate some advice on this and help mum having a waterlogged kitchen. Thx
DIY help!'
DIYhelpee is offline   Reply With Quote
Old 12-29-2011, 03:01 PM   #2
1. Don't turn on the cold water valve.
Or 2. Connect the cold water valve.
Billy_Bob is offline   Reply With Quote
Old 12-29-2011, 03:04 PM   #3
Experienced
Jackofall1's Avatar
I can't really figure out what you are trying to say, but if I read that right, the only pipe tied to the set of taps is the HW, if that is correct the only way to fix this is to tie the CW to the CW tap.
Mark
Old 12-29-2011, 08:25 PM   #4
Ok guys let me try connecting the cold water feed pipe to the cold water tap connection.
Let me see what results I get and I will come back to you
Thx for the help. Appreciated
Old 12-29-2011, 09:25 PM   #5
Rewards Points: 582
a faucet will back feed through it self if only one side is hooked up...how do you think you mix hot and cold to a desired tempeture....
Old 01-07-2012, 07:14 AM   #6
Thanks guys for the help. I finally got the taps to work without any leaks
Old 01-07-2012, 12:05 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Man I would have loved getting an hour for this one.
Journeyman Plumber
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-20-2009 12:53 AM
