Hot Water From Cold Pipes, Plumbers Are Stumped - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2013, 05:46 PM   #61
An old Tradesmen
Rewards Points: 6,586
As Sureshot stated, that seems unlikely to make any difference since the recirc pump adds a relative pressure to the hot water, so both would increase. And I should mention that for different reasons, I did increase the cold water pressure from 60psi to 70psi many weeks ago, but it had no impact on the problem.
Did you check if hot water is getting into the cold line from the recirc pump. Its check valve may not seat all the time.
Old 09-15-2013, 05:50 PM   #62
After the problem started, I hired plumber #1, who replaced the old (noisy) recirc pump with a fancy new one that has a built-in check valve. The problem persisted.
So I believe that the HW check valve is not to blame. Also, the old pump ran all the time, in which case I think a check valve is irrelevant. The new pump has a timer and thermal sensor, so the check valve has a chance to matter. But again, the problem predates this fancier pump.
/Seabeast
seabeast is offline   Reply With Quote
Old 09-15-2013, 05:58 PM   #63
An old Tradesmen
I was referring to the check valve that should be in the cold water line. To prevent the hot water from being pushed into it.
Old 09-15-2013, 07:14 PM   #64
Rewards Points: 1,772
Just for giggles sea beast could you turn off the cold to the hot water tank. Turn off the recirculation line hope it has a valve. Then open up the KS faucet hot only and see if it has any pressure after 3 or 4 minutes. It will take time to bleed off your expansion tank. Also turn your pump off on the recirculation line.
If the hot still has pressure then we are dealing with a cross connection and a Delta can do this. And your washer machine can also.
The Following User Says Thank You to Ghostmaker For This Useful Post:
seabeast (09-24-2013)
Old 09-15-2013, 07:31 PM   #65
Plumber
TheEplumber's Avatar
Rewards Points: 452
Have you done a 180 on this? I feel a faucet/mixer is the issue as well.
Or it could be as BT suggested, this thread is long and old- so many suggestions laid out but I can't remember whats been confirmed.......
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 09-15-2013, 10:29 PM   #66
Until about two weeks ago when I had a plumber install one, there was no check valve on the cold water line. So not sure what you mean by "should be there". There is one now, but never was one before, even way back when things worked properly.
But you do raise a good point: if the newly-installed check valve were failing to properly block reverse flow sometimes, that could explain the "sometimes" nature of the problem now.
I never actually got a good look at the check valve before the plumber installed it. He used a spring valve, rather than a swing gate valve as I had seen elsewhere.
The spring ball check valves seems pretty foolproof, though. Is this a plausible failure scenario?
/Seabeast
Old 09-15-2013, 10:48 PM   #67
Always Learning
I think the sometimes is the cold water usage. The problem is occurring at a junction of the hot and cold lines and can only happen when you have a pressure differential. So if your sprinklers are on a timer for 5AM and you get up at 7AM the "condition" has existed for 2 hrs and is noticeable. On days when someone turns on the shower and leaves it run a few seconds before testing the temp the condition goes undetected. The system is not that complicated so the solution shouldn't be either.
Is this a home run system or branch circuit or whatever they call it?
Is it just one tap or all of them?
Many pieces missing and some controlled testing needs to happen.
Try starting the sprinklers hours before the family rises and test each tap for the volume if any of hot that comes from it. That will narrow the problem. I suspect a check valve on the cold at that fixture will end the problem.
Is the water instant hot at the fixture when turning on the cold or starts cold and gets hot then goes cold. I suspect starts hottest and cools to normal cold in time telling you it is leaking through the fixture.
If it were way back at the tank it would have to displace the cold water from the line to replace it with hot. So where is the cold going if that is the case?
I think it is time to step back, clear the head, and take a fresh look and collect better data. JMHO.
Sureshot is offline   Reply With Quote
Old 09-16-2013, 12:04 AM   #68
An old Tradesmen
Yes it is.
Old 09-16-2013, 07:54 AM   #69
PoleCat's Avatar
Rewards Points: 1,646
Having read the whole thread it would appear that there is something about the new water heater that is the culprit. But that just doesn't add up no mater how you try to imagine it. It still comes back down to the observations made so far:
  1. Problem only occurs while recirculation pump runs.
  2. All fixtures are ambient temperature until turned on.
This implies that the cold water pipe is acting as the return either alone or in tandem with the intended return. To verify this I would go to the trouble of installing another ball valve on the cold line that supplies everything BUT the water heater. While this is shut off the only place water can flow is through the water heater and recirculation loop. Try some fixtures with separate valves(toilets, faucets, hose bib) If you get any water pressure from the cold you have proved there is clearly an open cross over somewhere.
Is it possible the water heater replacement may have involved some pipe modifications where the return line may have been mistaken for a supply line and re connected wrong?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-23-2013, 03:47 AM   #70
Bingo!
So, there was a breakthrough this weekend. Last week my son complained that he couldn't get hot water out of his shower anymore. So on Saturday I decided to replace the faulty valve. But before removing it, I tried Ghostmaker's suggestion and turned off the input to the water heater and the recirculating pump. Sure enough, the hot faucets in the house still had a pretty decent flow. And when I went upstairs to my son's bathroom, the shower valve in question was making the loud "woosh" sound of running water. Clearly that valve was a crossover point.
And here is also where I need to admit that I was wrong in something I stated previously: not all of our faucets are Delta. Turns out my son's shower (and probably 1 other upstairs shower) uses Price Pfister valves. And it seems the pressure balance valve failed in a way that let hot and cold mix.
After replacing the valve, our problem finally seems to be fixed. Strangely, even after fixing this valve I still get water from the hot taps when the hot water heater is cutoff from the supply. I read elsewhere that pressure balance valves can do that when one side has no pressure at all, so I'm not too worried, but a little.
So, finally I found an explanation for my problem that makes sense. After four plumbers, over $1000 spent on "improvements", and countless hours, it seems a $20 part was all I really needed...
Interestingly, our hot water seems a lot hotter now. Guess we were also really getting a lot of cold-into-hot mixing at that valve.
Thanks everyone for your help and support!! Hope this massive thread helps another poor soul someday...
-Seabeast
Old 09-23-2013, 05:24 AM   #71
An old Tradesmen
I think a bad shower faucet was suggested back in post number 2.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (09-23-2013)
Old 09-23-2013, 06:43 AM   #72
DIY staff
Rewards Points: 7,174
EPlumber gets the pot---
Glad you found the solution--Mike---
Old 09-23-2013, 11:05 AM   #73
No, Ghostmaker gets the prize. The shower valves were a suspect before I even posted here, as mentioned in post #1. That's why I had the first plumber check them.
Ghostmaker was the first to suggest an experiment that actually identified the culprit.
Ever see those signs in car shops that say something like "Parts $20, labor $20, knowing which part to replace $500." That was pretty much my situation.
The Following User Says Thank You to seabeast For This Useful Post:
Old 09-23-2013, 11:58 AM   #74
Always Learning
See also post #57. There might be some discrepancy as to what "disconnect" means but I meant physically disconnect it.
Ghostmaker's plan found it with less mess for sure and is a good thing to keep in mind. A person could use an IR gun and even find slower leaks by running hot through each fixture until hot then shutting the pressure off to the cold other than the water heater and "looking" for the heat moving into the cold side with a cold faucet open. In your case with the circ pump you would't need to run the hot as it is always there.
Old 09-23-2013, 06:34 PM   #75
DIY staff
Thanks for identifying the method used to find the problem----
Ghost maker wins the pot-----
insulating cold water pipes joefromcal Plumbing 8 06-06-2013 01:11 AM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 12:24 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
hot n cold water pipes in bath vanity handekaps Plumbing 4 01-10-2010 10:49 PM
