Hot Water In Cold - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2014, 07:57 PM   #16
Originally Posted by oh'mike View Post
I'll let a plumber answer this one---Does the water heater have an expansion tank?
No Expansion tank. When the hot water recirc pump is turned off the cold water pipe into the water heater does not get hot.
markstg is offline   Reply With Quote
Old 03-24-2014, 05:06 PM   #17
I've verified that it is NOT a single level shower and sink faucet. One shower has a stops on the valve body, and placed a rubber diaphragm between the cartridge and the valve body on the other two showers. Turned off the hot water stop to the 2 kitchen sinks single levers. How else can this be happening?
Old 03-25-2014, 06:08 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 542
Do you have a faucet that has the handles left on all the time -such as a laundry sink or washing machine. If so turn them off and run test.
Has any plumber or anyone else done any work on water piping inside the walls or ceiling?
Do you have any tub/shower valves that are in the rough in stage and not completed?
Do you have any remote located thermo mixing valves?
Old 03-25-2014, 06:45 PM   #19
Send a message via AIM to Marlin
The washing machine could be your culprit.
Marlin is offline   Reply With Quote
Old 03-26-2014, 07:21 AM   #20
No, No, No, and No.
I close the washing machine hot water stop and hot in cold water faucets still occurs.
OK, so when all single lever shower and faucets hot water are stopped and the washing machine hot water is stopped and I turn the hot water recirc pump off after 4 hours, the cold water in the cold water faucets stays cold. Turn hot water recirc pump back on, and waiting 30 minutes hot in cold water faucets returns.
Must be that the always hot water in my hot water piping is warming up the cold water in the cold water piping by them being in close proximity to each other. Don't know how it could be anything else. During rough in of the house I did not see any hot and cold water lines touching. This is a concrete slab house with water lines run in/below the slab, with a 2nd story, hot water heater installed in attic.
Geeez, how do I install a COLD water recirc system? This is a new house I built, (completed 1 year ago) I am the builder. Should my plumber be responsible for this?
Thanks for coming back to help.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
