Hot Water In Cold - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2014, 03:00 PM   #1
Hot water in Cold
Hello,
I have a Kohler 2975 thermostatic mixing valve in my shower. While taking a shower, every few minutes a brief (1 second) burst of very hot water comes out the shower head.
Do I need to replace the cartridge (1046104) and the check valves in the integral supply stops? Or just the cartridge or just the check valves?
I'm also thinking this is the culprit that is putting hot water in my cold water causing my bathroom sink faucet (2 handle) to have warm water in the cold for a few minutes upon 1st turning it on.
markstg is offline   Reply With Quote
Old 01-17-2014, 04:26 PM   #2
Rewards Points: 318
You can try to adjust the anti scald first, if no better, replace it.
No need to replace stops unless they are leaking. Lets see what others recommend.
jmon is offline   Reply With Quote
Old 01-17-2014, 05:18 PM   #3
Rewards Points: 13,994
It's the anti scald inside the valve not the stops.
jmon (01-17-2014)
Old 01-17-2014, 05:27 PM   #4
By anti scold I assume you mean cartridge?
Old 01-18-2014, 04:45 AM   #5
Rewards Points: 318
Yes, it's located in the cartdrige. Recommend you read pages 3-15, in your home owners guide first before doing anything (click on link). Great read, it addresses and explains your issues. Just a thought.
Just a suggestion, if no better, or still not satisfied, call kohler and explain to them the issue you are having, they may send you a new cartdrige and check valve at no charge. Hope this helps you a little better.
click here for kohler 2975 homeowners guide
Old 01-18-2014, 11:18 AM   #6
Thanks all. Kohler is sending a new cartridge. Lifetime warrenty.
The Following User Says Thank You to markstg For This Useful Post:
jmon (01-18-2014)
Old 01-18-2014, 12:01 PM   #7
Rewards Points: 318
Your Welcome.
Nice job Mark. Excellent, glad everything worked out for you and you saved some money.
Old 03-14-2014, 07:17 PM   #8
OK, replaced the shower cartridge discussed above and hot water spurts stopped, but still have the problem of multiple faucets with tepid (80 deg F) water for 30 - 60 seconds coming out of cold water faucet. Cold water temp is normally 65 deg F.
I have 4 other single handle faucets (2 shower, 2 sinks).
I have a hot water recirc pump with check valve piped to the drain of the water heater.
Can a single lever faucet bleed hot to cold without it being used?
Old 03-14-2014, 07:23 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 806
Moens can do this, not sure about other brands
Old 03-15-2014, 08:33 AM   #10
I have Delta and Kohler. I have the cartridge replacements for these 4 on order.
There does not appear to be a method to determine which one is the culprit other than to change one at a time and check results.
Any other ideas. This is a new house, completed 3/2013, and my plumber assures me that there is no physical contact between a hot water pipe and cold water pipe.
Old 03-15-2014, 09:09 AM   #11
DIY staff
Rewards Points: 7,174
turn off the shut offs under the sinks----that will stop any crossover--and allow you to figure out which one is the culprit.
Old 03-15-2014, 09:15 AM   #12
2 are in showers, so that is not possible, but that will narrow it down.
thanks
oh'mike (03-15-2014)
Old 03-18-2014, 05:36 PM   #13
Well changed all the cartridges and still have the hot water in the cold faucets. Noticed the cold water inlet to the hot water heater gets very hot. Any suggestions? Can't believe I bought shower valves without the stops. Live and learn.
Old 03-18-2014, 06:55 PM   #14
Here's a pic of the Water Heater with the recirc pump piped to the drain.
Old 03-18-2014, 07:47 PM   #15
DIY staff
I'll let a plumber answer this one---Does the water heater have an expansion tank?
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
