Hot Water Circulation Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2010, 02:20 PM   #16
In you first post you stated that even with the return valve closed you still get no hot water.
What that tells me is you isolated the recir system and you are still having problems , so here's what you should do.
SULTINI - The main reason for me starting this thread was to determine if what i'm experiencing is normal or if I have a problem. From what you say it sounds like I have a problem. I guess I need to try and figure out how to troubleshoot it. All pipes are in the slab or walls so nothing is really exposed.
westtx28 is offline   Reply With Quote
Old 02-13-2010, 02:24 PM   #17
tex Sounds like you got a problem but only can go by what we know without looking at your system and how it was Engineered.
You shouldn't need a recir system to get hot water, but only speculating.
SULTINI is offline   Reply With Quote
Old 02-14-2010, 07:34 AM   #18
Rewards Points: 1,542
Any other gizmos, for example an anti-scald system that commingles cold water with the hot, perhaps down near the water heater?
Yet another sump pump / pit question SeanFlynn Plumbing 0 01-24-2010 01:07 PM
Ice and water question rockee Roofing/Siding 14 05-03-2009 04:38 PM
City water pressure and volume question Jeekinz Plumbing 2 07-31-2007 12:18 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
