Hot Water Circulating Systems? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2009, 01:22 PM   #1
Rewards Points: 150
Hot water circulating systems?
Hi all,
Here I am with another question. On my new place the tankless water heater is in the detached garage quite a ways from the bathrooms (maybe 40-50 feet). I have to wait a long time to get some hot water in the shower and sinks. I have tried to read about hot water systems but I seem to find a range of mix opinions. Some say it is great and saves you energy, others say it is constly and not worth it. My house is single story 1650sqft and only have two bathrooms. Any suggestions, ideas, recomendations? I know there is a few systems out there but how to choose. I would like to have hot water right away but if its going to cost me a lot $$$ I may need to learn to deal with this problem.
gante is offline   Reply With Quote
Old 03-23-2009, 02:06 PM   #2
If you have a tank-less water heater your only choice would be a demand type recirculating. The fuel savings from a tank-less heater comes from the fact that it is not heating water except during demand. With a full time recirculating the heater would be running most of the time.
You might take a look here http://www.chilipepperapp.com/Default.htm
hayewe farm is offline   Reply With Quote
Old 03-23-2009, 02:16 PM   #3
Rewards Points: 1,492
A recirculation system can be expected to shorten the life of a tankless water heater by causing it to cycle on and off a lot.
AllanJ is online now   Reply With Quote
Old 03-24-2009, 10:02 AM   #4
Rewards Points: 150
Yes, I do not want to do this to the heater. I guess I will have to learn to deal with the cold water.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Possible to convert hot air heat to water circulating radiators djtjak43 HVAC 3 01-11-2009 07:58 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
