Hot Water Cast Iron Radiator Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2009, 10:56 AM   #1
Unhappy
Hot water cast iron radiator valves
Can i use the valves on the radiators to control water flow? they don't seem to work when i turn them the piping is parallel and i have 2 small rooms that stay cold when the rest of the apartment is warm i want to constrict the water flow to the other 4 rooms and i think this should cure the problem however the valves don't seem to operate.
EHP@WRFD.ORG is offline   Reply With Quote
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 06:24 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
