Hot Water Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2011, 11:27 AM   #1
Unhappy
hot water boiler
The heat in my house is supplied thru the baseboards connected to hot water boiler
I noticed the safety relief valve leaking slowly, so I changed it & installed a 30 PSIG new safety relief, but it is still leaking
I do not have a expansion tank, instead i have a 20 gallon tank above the boiler and this tank is not full
why is it still leaking when the boiler is in use.
lakhias is offline   Reply With Quote
Old 11-29-2011, 12:24 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,.... What is the Pressure showing at the pressure gauge,..??
If it's approachin' 30psi, when Hot, yer expansion tank is probably more Full than ya think...
Old 11-29-2011, 12:27 PM   #3
leaking relief valve
The pressure is 12-15 PSI when the boiler is on, I have tried to drain the water from the system to keep the pressure @ 10 psig, even than it leaks
Old 11-29-2011, 05:56 PM   #4
Civil Engineer
Rewards Points: 4,686
That 20 gallon tank above your boiler is an expansion tank. I have one just like it at home. Draining the expansion tank is a little harder than it sounds, if it is the old style tank (sounds like you have an older style one), you need to close the inlet valve from the boiler to it, then open the sillcock on the tank, and drain it completely. I use a garden hose to do this. It may not be possible to let air in while you do this, in which case it takes a long time to drain, since the air has to come in through the hose. Kind of makes a burping sound. Takes mine about half an hour to drain, need to do it once a year.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
ben's plumbing (11-29-2011), lakhias (11-30-2011)
Old 11-30-2011, 10:00 AM   #5
Smile
thanks daniel, I will try it today
Ash
Circ Pump? Water heater? Boiler? diamondjoe Plumbing 1 12-25-2010 08:20 PM
boiler and hot water venting AdamBNYC Plumbing 3 08-26-2010 05:09 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
