HOT Water On Bathtub Faucet Not Working?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 10:40 PM   #16
yea pretty sure i had it all the way in there....
tibasnatch is offline   Reply With Quote
Old 02-04-2012, 11:00 PM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Once its all the way in against the cartridge the ears on the puller should fit into the sides of cartridge and lock against it,then you can twist the handle on the puller to break cartridge loose from the faucet.
Then you tighten the nut ,this should pull against the cartridge while pushing against outside edge of faucet to remove cartridge
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 12:22 AM   #18
so I got it to come out about 1/8 of an inch..and im pulling pretty good not full strength and its even turning a bit inside soes it take a ton of pulling to get this out?
I shut the water off to the house if i cant get this thing all the way out and i turn back on the water is it going to leak?
Old 02-05-2012, 12:29 AM   #19
plummen's Avatar
Yes youre committed unless you can push it back in and reinstall the clip
Old 02-05-2012, 12:36 AM   #20
well i pushed it back in but now the HC is at bottom instead of top....I will tackle it more tomorrow cause my wife need to take shower before work....if it is pushed back in turning back on water should be ok? i hope
Old 02-05-2012, 12:41 AM   #21
plummen's Avatar
As long as you get the clip back on you should be ok.
The hot/cold will probably be reversed now with cartridge being upside down,no big deal though
Old 02-05-2012, 12:55 AM   #22
well i turned it back on and no leaks that i can see inside the wall but now the water wont stop running into the tub no matter which way I turn it.....so i turned off water til she needs it for shower.....ill try to get it out rest of way tomorrow.
Old 02-05-2012, 12:56 PM   #23
yay i got it out...that was a battle!! the orings were holding it in there they pretty much ripped apart coming out....time to go get correct cartridge and hope it fixes the problem!!
Old 02-05-2012, 01:06 PM   #24
plummen's Avatar
Before you install the new cartridge check inside of faucet for any trash/burrs,slop the new cartridge up with plumbers grease really good before installing it to protect the o-rings
Old 02-05-2012, 06:51 PM   #25
SWEET!! New cartridge worked....hot water now works fine...thank you SOOOOOOOOOOOOOOOOOOOOOOOOO much for the help...not I dont have to call a plumber.
The Following 3 Users Say Thank You to tibasnatch For This Useful Post:
ben's plumbing (02-05-2012), plummen (02-05-2012), TheEplumber (02-05-2012)
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 11:47 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Low water flow bathtub faucet osirus065 Plumbing 3 09-07-2009 11:51 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
