HOT Water On Bathtub Faucet Not Working?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 04:34 PM   #1
HOT water on bathtub faucet not working??
In our bathtub if you turn the faucet to HOT the water shuts off...the cold runs fine but as soon as you turn past 1/2 way it shuts off....here is a video of what it is doing.
http://s210.photobucket.com/albums/b...203_152419.mp4
tibasnatch is offline   Reply With Quote
Old 02-04-2012, 04:39 PM   #2
Rewards Points: 582
seem like either a valve is shut off..or the cartridge on the faucet may be clogged or defective...
Old 02-04-2012, 04:42 PM   #3
The valve like in the wall? and can the cartridge be cleaned/replaced easily or have to cut into wall?
thanks
Old 02-04-2012, 04:45 PM   #4
Rewards Points: 582
if you look at faucet the white part behind the clip is the cartridge shut off water remove holding clip pull out cartridge clean out or replace....you may try with help blowing out line... thats the small part in the center where handle would go....
Old 02-04-2012, 05:05 PM   #5
Ok...i turned off water and removed the clip but white cartridge isnt wanting to come out....should it slide forward and out?
Old 02-04-2012, 05:10 PM   #6
Rewards Points: 582
yes it should it may be tight but it should come out....is that a moen if it is you may need to buy a puller.....Inever had too always just pulled it out...
Old 02-04-2012, 05:14 PM   #7
yes it is a moen....its seems pretty well in there.
Old 02-04-2012, 05:18 PM   #8
Rewards Points: 582
leverage is key ..I grip with vise grips then wedge against opening to pry out...be careful not to damage anything...if unsure home depot or lowes sells puller 10.00-15.00 dollars...
Old 02-04-2012, 05:35 PM   #9
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
this looks to be the puller....should I go ahead and buy a cartridge too? are they universal or would i need a model number and stuff.
Old 02-04-2012, 05:38 PM   #10
Rewards Points: 13,446
If you contact Moen they would send you one for free.
MY money goes on the antiscald valve is stuck from trash in the line inside the valve.
Old 02-04-2012, 05:42 PM   #11
if you are correct what would that require me to do?
Old 02-04-2012, 05:42 PM   #12
Rewards Points: 582
I have not done alot of work on moen but I think i would buy a cartridge while there can always return it ....would help if you had model ...take a good look at cartridge before you go ... its about 4" long...
Old 02-04-2012, 09:56 PM   #13
well that didnt work...the puller i bought wouldnt reach all the way to white part and ate up the white part....im just calling a damn plumber....thanks anyways for your help.
Old 02-04-2012, 10:30 PM   #14
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Sounds like a good way to pull the stem right out the center of it,save yourself a lot of headaches and just buy a puller for it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-04-2012, 10:34 PM   #15
plummen's Avatar
Did you run the screw all the way out on the puller and crank the nut all the way back on puller before seating it against the cartridge?
they can be a pain sometimes if theyre stuck in there,the older brass ones can really suck sometimes!
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 11:47 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Low water flow bathtub faucet osirus065 Plumbing 3 09-07-2009 11:51 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
