Hot Water Baseboard Heater Elemets - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2013, 09:39 AM   #1
hot water baseboard heater elemets
Hi, I need to replace the old space heaters elemets in my home and want to know is it better to cut off the pipe ending or heat up with a torch to remove them to add new ones,,thank you.
adrie22 is offline   Reply With Quote
Old 09-01-2013, 10:54 AM   #2
DIY staff
Rewards Points: 7,174
Usually best to unsolder them and quickly clean the pipe----
cutting will put your repair coupling rather close to the finished floor.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
