Old 02-12-2008, 01:05 PM   #1
Hot Water Baseboard does not work
Please help. I have a hot water base baseboard that is not working. It is a new install ( last Year). I bled all other base boards and standups that I have in the house and this is the only one that does not heat up. There is a bleed valve on both sides, hot water comes out on one side but cold is on the other, shall I keep bleeding until both sides have hot water???
iwolff is offline   Reply With Quote
Old 02-12-2008, 03:33 PM   #2
What level is the unit on?
What is the PSI reading on the boiler?
redline is offline   Reply With Quote
Old 02-12-2008, 05:46 PM   #3
Send a message via AIM to Marlin
You have air trapped somewhere. Have you purged the base board? When you installed it did you run the pipe up then back down again anywhere that could create an air trap?
Marlin is offline   Reply With Quote
Old 02-13-2008, 08:47 AM   #4
the baseboard is on the first floor. Not sure what the PSI is. I would have to check. Would there be a meter or do I have to attach a Meter??
Old 02-13-2008, 08:49 AM   #5
When it was installed It worked. The baseboard was run off main, obviously but onlyto that baseboard. Should I keep bleeding that baseboard unitil I get the hot water, or is there somewhere else I I should try bleeding.
Old 02-13-2008, 09:16 AM   #6
Joe F's Avatar
This sounds very odd to me. For one side to get hot there needs to be at least some water flowing. Right? Especially if all the other baseboards get hot. Is it possible that this baseboard has an internal blockage?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 02-14-2008, 07:19 AM   #7
Should be a gauge on the side of the boiler.
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Hard water - 37 gpg, .088 iron content. What softener will work? fillys6 Plumbing 9 04-27-2007 10:55 PM
Hot Water Baseboard Heat danthemandan HVAC 1 03-19-2007 10:27 AM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 06:08 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
