Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2010, 11:48 PM   #1
King Construction Inc.
Hot water
I have very hot water for a very short time. What do I need to do?
nking is offline   Reply With Quote
Old 10-29-2010, 07:05 AM   #2
I assume you mean you quickly run out of hot water??? If yes, the problem is probably a disentegrated dip tube. It is a tube under the cold water inlet and direct water to the bottom of the tank. When they break off, cold water dilutes the hot water at the top quicker than normal. Fairly easy to replace, but depending on the age of the heater, it may be worth consider replacing the heater. Another telltale symptom is the appearance of little white flakes clogging the faucet aerators.
Old 10-29-2010, 11:16 AM   #3
jlhaslip's Avatar
Rewards Points: 396
If your water source has a high level of minerals, they might be caking the inside of the tank, thereby reducing the tank's available volume.
Happens here a lot.
The fix is to replace the tank. They are difficult to clean out.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-29-2010, 02:53 PM   #4
Homerepairguy's Avatar
Rewards Points: 990
If you have a standard (not solar) electric water heater, your lower heating element may be burned out or the thermostat might be bad.
In standard electric water heaters, there are two heating elements, one higher up and one lower. If the lower element does not go on, hot water will occur in only the top 1/3 or so of the heater.
If this is the type of water heater you have and need help in determining whether it is the heating element or the thermostat, shout and I or someone will help you out.
Homerepairguy is offline   Reply With Quote
Old 10-31-2010, 08:21 AM   #5
Rewards Points: 1,418
You should not have to use the "very hot" setting on the water heater dial.
When you turn the dial down and then get a very short time of usable hot water, then the above mentioned problems need to be investigated.
Almost all electric water heaters have two thermostats, one under each cover plate. Both should be set to the same temperature. About 120 degrees is today's recommendation for home use. You can go a little higher if there are times when several baths are taken in a short period of time.
*** I don't know when there is a legitimate use for the very hot setting, any more than the 100 plus mph portion of a car's speedometer. I suppose that from time to time a home grade water heater is installed in a commercial setting such as in a restaurant, where 180-190 degree water is needed, but this usually means a somewhat shorter life span and voided warranty for the heater.
Old 10-31-2010, 09:00 AM   #6
the Musigician
DangerMouse's Avatar
This seems to be the most common (and easiest to fix) reason for this behavior.
HRG gets my vote on this one.
DM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
