Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2014, 05:27 PM   #1
hot water
I'm stumped...we have two 40gallon water tanks run parallel so hot water shouldn't and never has been a problem, until recently. We've been running short on hot water in the tub in our master bath and the hall shower, and now this afternoon along with the tub the sinks in the master bath. The pressure is fine and the water is warm, but not hot at all. I've cranked up the temp on both water heaters, the flame is going strong and they're both really hot to touch. I thought initially maybe something was up with one of the valves to the tub since it probably has an anti-scalding valve, its probably 15 years old so maybe something has gone wrong, but it seems really odd that the hall shower is having the same problem (its only about 4 years old, single handle moen) and now the bathroom sinks as well. All copper, pressure is fine, tanks appear to be very, VERY, hot...but only warm/hot by the time we get it out at the tub and shower.
For the most part its happening at random times, not necessarily after running washing machine and/or dishwasher and sometimes when neither has been run in hours.
mess94 is offline   Reply With Quote
Old 01-19-2014, 05:43 PM   #2
Rewards Points: 22
If you able, turn off the supplies to your shower and see if it fixes the problem. I'm suspecting the cartridge is bad and it's allowing cold water to mix in the hot water line.
Do the same if your tub has a single valve.
Also, turn the temps back down on your heaters. I'm sure you know it's dangerous.
Dan
djlandkpl is offline   Reply With Quote
The Following 2 Users Say Thank You to djlandkpl For This Useful Post:
mess94 (01-19-2014), plummen (01-20-2014)
Old 01-19-2014, 08:06 PM   #3
Rewards Points: 582
yep sounds like a cross over at a single control faucet...start to isolate each fixture one at a time and trying it to see if you can trace it to a certian fixture...ben sr
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
