Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2013, 10:05 PM   #46
beginner50's Avatar
Ok yeah ill see what I can find when I have more light and have a better idea of what to look for!
beginner50 is offline   Reply With Quote
Old 03-03-2013, 10:09 PM   #47
Rewards Points: 282
Great. I just don't want you to get in over your head with this project. Those are really old pipes, it's very difficult to work with threaded galvanized without the proper tools necessary to complete the job. That's probably why the previous owner just shut it off and left it alone. You never know what else you may run into when fixing it. Unfortunately, someone has to fix it, just wished for your sake it was pex or copper. Just remember, you will have all the water to your house shut off, if you run into problems you may be without water until you fix it.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
beginner50 (03-03-2013)
Old 03-04-2013, 10:52 AM   #48
Rewards Points: 282
Here's a link to help you with your project. Hope it helps. It explains exactly how to do this project.
link here
That's about all the advice I can give you bro. It's up to you from here, if you feel comfortable and have the skill set, the proper tools, go for it. If not, hire a pro. Galvanized pipe is harder to work with, but it can be done. Hopefully the plumbers installed a union somewhere so you won't have to cut the pipe and do all that work to replace the valve. Now you know why the previous home owner just shut it off and left it alone.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
