#16 |
Hot water
Roger that. Do you know if plumbing was updated? What kind of pipes? copper, galvanized? etc.
#17 |
Hot water
Did the tip that dj suggested help? Where you able to trace the hot water pipe. Sometimes in older homes you never quite know how they plumbed things. Start at your hot water heater, and try to find the hot water pipe going upstairs to second floor. There may be a seperate line that goes directly upstairs that has a gate valve or ball valve that may be closed somewhere. It may be closed for a reason, I don't know, so be careful.
#18 | |
Hot waterQuote:
#19 |
Hot water
Still no luck? You say that when you turn on the hot water to both of these fixtures nothing comes out. Is that correct?
#20 |
Hot water
Well figured it out!! The guy who was renting it out owns a plumbing company, his son lied to me said he just repacked the valve but he actually just tightened the hell out of it!! I finally got it open and just sprayed every where but I had my wife try it out while I did that and sure enough the hot water came on!! Now do I just replace the valve??
#21 |
Hot water
Cool. Can you post a pic of the valve?
Dan |
#22 |
Hot water |
#23 |
Hot water
That's what I figured, in older homes they used a lot of gate valves and threaded galvanized pipe. Oh well, it's doable. Going to try and diy or call a pro? Nice pics by the way.
#24 | |
Hot waterQuote:
#25 |
Hot water
That's what this open forum is all about.
#26 | |
Hot waterQuote:
#27 |
Hot water
Do you have tools? Make sure you have the right tools for the job first. You will need a couple of big wrenches, vice grips, breakfree. 1 pipe wrench and 1 big 12 inch cresent.
#28 | |
Hot waterQuote:
#29 |
Hot water
yea, i know, but they are threaded - sometimes they are hard to get apart. Do you have big pliers? You may be able to do it with what you have. How about that guy renting it out. does he have some tools?
#30 | |
Hot waterQuote:
| Display Modes | |
| Water heater solutions to get hot water in timely manner | daluu | Plumbing | 22 | 05-07-2012 09:44 PM |
| Oil fired furnace and hot water heater question | steveinpa | Plumbing | 3 | 08-10-2010 09:42 AM |
| water borehole question | joeuser | General Discussion | 2 | 04-18-2010 11:33 PM |
| How Do I Properly Shock Chlorinate a Water Softner | classicflytyer | Plumbing | 5 | 07-14-2009 01:15 AM |
| Low Hot Water Pressure | btennant | Plumbing | 4 | 12-09-2008 10:31 PM |
