Old 03-03-2013, 07:26 PM   #1
beginner50's Avatar
Hot water
My hot water in my upstairs master bath will not work?? It works every where else in the house kitchen, bathroom and tub! The cold works up but hot will not in the sink or tub!! Any advice??
beginner50 is offline   Reply With Quote
Old 03-03-2013, 07:28 PM   #2
Hot water
Do you have no water or is the water cold? Any details on the type of fixture that's in the bathroom?
djlandkpl is offline   Reply With Quote
Old 03-03-2013, 07:33 PM   #3
beginner50's Avatar
Hot water
Yeah I have cold water, but in the sink and tub when you turn the handle no water comes out. When I moved in the hit water handle was busted off and I just today replaced the tub faucets. The cold side comes out but none on the hot handle! The faucet I just put in is called Tuscany baldwell collection, that's all I know! But every where both hot and cold work fine!
Old 03-03-2013, 07:42 PM   #4
Hot water
If it's a sink and tub (2 fixtures), there's probably a shut off valve somewhere that is closed.
Old 03-03-2013, 07:46 PM   #5
Hot water
How long has this been going on? How old is house?
jmon is offline   Reply With Quote
Old 03-03-2013, 07:57 PM   #6
Hot water
Like dj above suggested make sure there is not a hot water shutoff valve closed somewhere. Will go from there.
Old 03-03-2013, 08:00 PM   #7
beginner50's Avatar
Hot water
So there can be a shutoff between floors?? The first and second floor bathrooms are on top of each other. The house was built in 1915 and since I moved in about 2 months ago its been like this!
Old 03-03-2013, 08:02 PM   #8
Hot water
Very possible. Look under sinks and any access panels. Check your basement/crawlspace too.
Old 03-03-2013, 08:28 PM   #9
Hot water
Do you rent, own, or lease? Any mention about it from previous owner/renter when you moved in?
Old 03-03-2013, 08:28 PM   #10
beginner50's Avatar
Hot water
Nothing but the valves under the sinks and there open!!
Old 03-03-2013, 08:29 PM   #11
beginner50's Avatar
Hot water
Buying it, and nobody said a word to me!!
Old 03-03-2013, 08:41 PM   #12
Hot water
I just read some of your other posts. Quite the plumbing at your house.
Run the hot water in your working faucets for a few minutes to get the pipes hot. Start at your hot water heater and follow the pipe. Look for valves and feel it to be sure it's hot. Try to track it where it goes up into the first floor and possibly where it goes to the 2nd from the 1st floor.
Old 03-03-2013, 08:43 PM   #13
beginner50's Avatar
Hot water
Ok I'll try that and see what I come up with!!
Old 03-03-2013, 08:44 PM   #14
Hot water
I hate it when people do not disclose this kind of information when closing. They keep it hushed up and hope you don't notice it until after you sign.
The Following User Says Thank You to jmon For This Useful Post:
beginner50 (03-03-2013)
Old 03-03-2013, 08:46 PM   #15
beginner50's Avatar
Hot water
Well to be honest the wife made the deal I was working close to 90-100 hrs a week so any off time I was sleeping so I wasn't around to check it all out!!
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
