Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2012, 12:55 PM   #1
hot water
My Hot Water Runs Normal Then Slow After A Few Seconds
12Doc12 is offline   Reply With Quote
Old 07-09-2012, 11:22 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
In all the fixtures or just in one? If in all start by checking the incoming water shut off valve for full open position. start there.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 07-10-2012, 07:29 AM   #3
biggles's Avatar
bottom drain hose hookup should be just like cold water pressure but hot.if it is on all the faucets then the copper pipe out of the top of the heater is building up minerals narrowing down the opening..or the pick up rod within is breaking down and retricting hot water out.
Old 07-10-2012, 07:49 AM   #4
Rewards Points: 52
How old is your home? Is any or all of your plumbing galvanized pipe?
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
