Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2011, 04:49 PM   #1
Hot Water
The shower is a long ways from the hot water heater. No full basement there is a crawl space under the shower . The Mrs complains about the time it takes to get hot water. Can a pump be installed to circulate the hot water to this shower? Tee into the line & run line back to the heater & install a pump? Any suggestions? It is a waste of water & electricity!!
RDH1958
RDH1958 is offline   Reply With Quote
Old 09-01-2011, 06:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 922
Yes, you can install a circulation loop and pump at your water heater. Your existing pipe layout will determine the cost and/or savings.
You can also install a retrofit pump system under your bathroom lav. Very simple project. No additional piping is needed.
You'll hear all kinds of pros and cons about recirc systems in regards to their cost and efficiency, but I'm all for them.
Old 09-08-2011, 12:06 PM   #3
I have the same problem. It wastes water trying to wait for hot water before you actually start to take a shower. I didn't know there was a simple solution, thanks for the information.
metal is offline   Reply With Quote
Old 09-08-2011, 03:39 PM   #4
Msradell's Avatar
Rewards Points: 348
We installed a circulation loop during our recent master bathroom remodeling and love it! We also thoroughly insulated all the hot water piping that was accessible. We really haven't noticed any increased energy consumption so whatever there may be is very small.
Msradell is offline   Reply With Quote
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
