Hot Upstairs But Cold Downstairs - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 02:56 AM   #1
Hot upstairs but cold downstairs
Hi all
got a problem with my heating, the radiators upstairs are always hot and we have no problems there. but the ones downstairs just seem to do what they want. sometimes they work and heat up (all over not just at the bottom) and sometimes they just don't doanything and stay cold. Even though the ones upstairs are boiling out.
Also my boiler has started making a loud popping noise.
Anybody got any ideas. Its freezing downstairs
Barton6435 is offline   Reply With Quote
Old 12-20-2010, 06:54 AM   #2
Rewards Points: 1,216
You might have balance valves on the return lines that have to be adjusted to limit the hot water to the upstairs loop and send more Hot water to the lower level. if you find the vales and attempt to adjust them I recommend you mark the starting point so you can go back to square one if need be. Or maybe you have a 2 zone system and the downstairs zone is not working.
COLDIRON is offline   Reply With Quote
Old 12-20-2010, 08:08 AM   #3
Not sure what type of system i have, i've given in and just phoned a plumber seeing my daughter shivering in the living room is no fun. However since i phoned the radiators downstairs have kicked in and are now boiling hot. just dont get why they work sometimes and not others
With heat, warm upstairs, cold downstairs. Smitty258 HVAC 11 10-18-2009 09:58 PM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 04:01 PM
Transitioning paint from upstairs to downstairs Madman78 Painting 3 08-28-2009 09:54 PM
upstairs hotter then downstairs.. f8lyer8s HVAC 6 06-18-2009 01:13 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
