Hot Tub Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2012, 10:32 PM   #1
Unhappy
Hot Tub repair
Long story short, Pipes in the hot tub froze last winter, I ordered the replacement manifolds, It is 2 In pcv with 6 barbed nippels that go to the jets with a 3/4" clear flex. I am having touble getting the clear tubing onto the barbed fittings, any ideas for an easy way to do this?
Eric_H_E is offline   Reply With Quote
Old 05-09-2012, 10:37 PM   #2
Rewards Points: 12,856
Heat them with a hair dryer.
Eric_H_E (05-10-2012)
Old 05-10-2012, 12:08 AM   #3
Personally I'd try vaseline, plumber's grease, dish soap, anything slippery.
VIPlumber is offline   Reply With Quote
Old 05-10-2012, 11:21 AM   #4
ill try the hair dryer, on the old manifold, the clear tubing was glewed on. I dont know what kind of glew but it was blue. I have hose clamps just in case. Thanks for the idea.
Old 05-10-2012, 01:40 PM   #5
didnt use a hair dryer, have a heat gun. I worked grate. Thanks for the tip.
now fouind a nother leak in a bubler. now looking for a replacement parts.
Tags
hot tub plumming
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
