Old 10-11-2012, 10:37 PM   #1
Still Learning
hot tub is not so hot
You can I tell of the heater works on the hot tub? I can feel of turn on when I push the button but after an hour of running it was still cold. Thanks for the help?
thehvacguy is offline   Reply With Quote
Old 10-12-2012, 06:45 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Yer a Hvac guy,..??
I'd check the heating unit with a multimeter...
Turn it on, is it gettin' Power,..??
Does it ohm out correctly,..??
It's nothin' but a water heater element, anyways....
Old 10-12-2012, 02:00 PM   #3
Still Learning
How do I.determine what the correct ohm reading would be? I don't see any labels or anything...
Old 10-12-2012, 03:29 PM   #4
Still Learning
I see where the wires connect to the heating element, and its reading 120v which tells me that its an open circut I guess
Old 10-13-2012, 09:33 PM   #5
Only one heating element?
I say just go buy a new element and change it out, see if the new one works, cant cost that much. You've already got a hot tub sitting there, might as well.
AZJefe is offline   Reply With Quote
