-   -   hot tub is not so hot (http://www.diychatroom.com/f7/hot-tub-not-so-hot-159801/)
thehvacguy 10-11-2012 10:37 PM
You can I tell of the heater works on the hot tub? I can feel of turn on when I push the button but after an hour of running it was still cold. Thanks for the help?
Bondo 10-12-2012 06:45 AM
Ayuh,.... Yer a Hvac guy,..??
I'd check the heating unit with a multimeter...
Turn it on, is it gettin' Power,..??
Does it ohm out correctly,..??
It's nothin' but a water heater element, anyways....
thehvacguy 10-12-2012 02:00 PM
How do I.determine what the correct ohm reading would be? I don't see any labels or anything...
thehvacguy 10-12-2012 03:29 PM
I see where the wires connect to the heating element, and its reading 120v which tells me that its an open circut I guess
AZJefe 10-13-2012 09:33 PM
Only one heating element?
I say just go buy a new element and change it out, see if the new one works, cant cost that much. You've already got a hot tub sitting there, might as well.
