Hot Cold Water Cross Circuit - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 12:11 AM   #1
Rewards Points: 87
The plumbers who did some rough plumbing took some part out of my shower valve that apparently prevents the hot and cold water from mixing prior to the faucet handles being installed and so my hot water is more of a luke warm water now
What is this part called and how can I replace it / fix this? I can get a hold of the plumbers but I do not know if they will have the part.
hellonoko is offline   Reply With Quote
Old 10-14-2013, 04:00 AM   #2
DIY staff
Rewards Points: 7,174
That is a Delta 'rough in ' valve body----with a test cap----You need to install the cartridge in order to stop the crossover====
This is a common occurrence---although a pro plumber should have known the parts needed to be installed---Mike----
The Following 4 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (10-14-2013), hellonoko (10-14-2013), Javiles (10-16-2013), plummen (10-15-2013)
Old 10-14-2013, 04:02 AM   #3
DIY staff
Just curious,why is there plywood in the shower?
Old 10-14-2013, 10:53 AM   #4
Rewards Points: 87
Thanks, the plywood is just there temp to cover some things.
Old 10-14-2013, 05:32 PM   #5
Rewards Points: 582
yes its a delta faucet and yes that part is the cartridge ..most plumbing places including lowe's and home depot should have them ..even ace hardware, ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
hellonoko (10-14-2013), oh'mike (10-14-2013)
Old 10-15-2013, 06:35 PM   #6
Rewards Points: 87
I have installed a cartridge and I still seem to have a cross circuit and get hot water. What else could be causing this?
Old 10-15-2013, 06:38 PM   #7
DIY staff
The faucet /cartridge is in the 'ON' position. Turn it 'off'----(good luck figuring out where 'off' is)
Old 10-15-2013, 06:41 PM   #8
Rewards Points: 582
look at the cartridge there is H on the one side this must face the hot side of the unit....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Warm water coming from cold faucets ygillard Plumbing 2 03-02-2012 03:24 PM
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 05:19 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
