Old 02-02-2013, 08:55 PM   #1
Hot or cold supply for the dishwasher
25 years ago all the dishwashers I installed were always hot supply. I asked the boss one day and he said that the real expensive washers have two supply inlets, one for the hot to wash and one for the cold to rinse. Now I am thinking that if the dishwasher has to heat the water from a cold only supply that it is using electricity instead of natural gas. Logically you would think it better hot shortening the cycles and saving power. Now realizing that engineers have better ways of doing things. Such as expensive electronic sensors that detect water temperatures. The cycles are probably done all from water temperature so if hot water is used the whole machine is disabled. What is better hot or cold, and do they still make dual inlet machines? What would happen if you piped hot into a cold only dishwasher?
paintdrying is offline   Reply With Quote
Old 02-02-2013, 09:04 PM   #2
Master Plumber
Javiles's Avatar
never seen a dual inlet dishwasher as far as i know hot wash hot rinse, machines bring up the temp via heating element. change in temperature could damage items put in to the machine to wash.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-03-2013, 07:20 AM   #3
installed hundreds of dishwashers. never saw a "dual water supply" one. not saying it aint so though. i installed some high dollar ones too. above post sounds dead on right about damage. i would venture to say boss is full of it.
buddy builder is offline   Reply With Quote
Old 02-03-2013, 09:47 AM   #4
JOATMON
ddawg16's Avatar
Would your boss by any chance be one of those guys that has seen everything? Is an expert on every subject? Slept at Holiday Inn Express last night?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 02-03-2013, 10:04 AM   #5
The boss would get in such a hurry he would jump out of the truck before putting it in park. He almost got dragged to death one morning. Not going to even comment on his workmanship. He would explain the job about a quarter of the way through then just run off. Come back an hour later and just start yelling that is not what he wanted. Then leave again.
Old 02-03-2013, 01:37 PM   #6
Use the hot water connection.
The dishwasher heating element will not heat cold water to proper temperature fast enough during the dishwasher cycle.
It is a good idea to run the hot water faucet from the nearby kitchen sink until the water gets hot prior to starting the dishwasher.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 03:39 PM
In AZ, hot water from the cold water pipes maynard7 Plumbing 12 08-06-2011 02:43 PM
Water heater T&P plumbed to cold supply rjniles Plumbing 5 05-21-2011 05:42 PM
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 08:39 PM
Dishwasher installation Andy Griffith General Discussion 3 03-02-2009 07:06 AM
