Hot & Cold Shower "valves" - Any Actual Pictures Of How They Are Put Together? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 06:25 PM   #1
Hot & Cold shower "valves" - any actual pictures of how they are put together?
I have been searching all over this forum ... Maybe I don't have the correct term - I have an old fiberglass shower with 2 separate handles - COLD and HOT - for turning on/off the water. I'm trying to figure out how this thing is assembled so that I know how to remove it and possibly repair it. I *think* the stem itself might be bad, if that's what it's called.
cody21 is offline   Reply With Quote
Old 05-14-2010, 07:17 PM   #2
Rewards Points: 266
Short of posting pictures, if you knew the brand there are folks on here who can help you. are you talking about the old style faucets with washer or washerless?
I've been replacing the washers, valve stems and occasionally faucet seats on my old gerber faucets for years. I can tell you for that style you will need a faucett wrench set. They look like large deep well sockets and use a metal stem through a hole on the end to turn. If the handels are froze on after you remove the center screw, you may need a faucet handle puller. If the seat needs replacing, they make a seat wrench for that. It pays to turn these types of faucets half way on, with the supply shut off of course. Otherwise you run the risk of unscrewing and removing the faucet seat when you unscrew the faucet stem.
Those instructions only aply to the washer type faucet. The washerless is a different animal and has a cartridge that comes out.
Jim F is online now   Reply With Quote
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
shock in shower tbwoods Electrical 64 07-23-2009 12:26 PM
Loose sand under shower tiles pictures RodJ Kitchen & Bath Remodeling 1 03-30-2009 07:26 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
