Hot & Cold Knobs For Shower....Coould Use Some Help!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2012, 08:42 PM   #1
Hot & Cold Knobs for shower....Coould use some help!!
Hey guys,
I got the standard shower knob setup, hot on the left, shower in the middle, and cold on the right. When the hot is turned on, it has to be turned a few times before the water actually comes out and then it seems like it doesn't have much pressure after a few more turns.
On the other hand, with the cold water it is kind of the opposite. I barely turn it on and the water is coming out faster and with more pressure.
It seems like the knobs are not calibrated or something. Any help would be extremely appreciated because plumbing, faucets is not my thing.
homie
homiefb is offline   Reply With Quote
Old 12-26-2012, 08:53 PM   #2
Rewards Points: 6,652
Crud and minerals clogging the hot water valve, is why you are getting lower flow on that side.
Old 12-27-2012, 09:31 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It might even be that your washer has come loose from your stem and is stuck against the seat. You'll have to turn off the water to the house and take apart the hot side valve to figure out what's going on.
Journeyman Plumber
Old 12-31-2012, 05:35 PM   #4
Thanks guys for all your help and input. I went ahead and replaced the seat and flat washer on both the hot and cold sides. It stopped a leak that had started right after I had made this post. Every thing seems to be working very well.
With a new seat and washer, the cold knob turns much better than before. It is not very hard to turn since the washer is the right size. I still do notice that I have lower flow on the hot side compared to the cold side. Now I just want to ask, should my next step is to replace the hot water valve? Now that is the part that I took off earlier to replace the washer on right?
homie
Old 12-31-2012, 08:45 PM   #5
Doing it myself
Alan's Avatar
I suppose that depends on how much lower the flow is on the hot side.
You may have decreased flow if you only have a 1/2" line feeding the hot line throughout the entire house (this is common in older homes) Could even be a partially kinked piece of soft copper, or even a partial blockage if you have some galvanized somewhere that is closing up.
Journeyman Plumber
Tags
hot cold shower problem , plumbing , shower knob
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 05:50 PM
Cold Air timmy k HVAC 0 12-14-2010 06:26 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 11:00 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
