Hot Cold Copper Lines Crossing Over Each Other At An Angle - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2012, 12:49 AM   #1
Rewards Points: 49
Hot Cold copper lines crossing over each other at an angle
From the water heater to the wall, I wanted to run the hot and cold water copper lines crossing over each other at an angle so that in the wall the cold will be on the right and the hot on the left. Running at an angle eliminates two 90 bends.
Do you think running at an angle non parallell to the 2x4's is ok with the inspector?
Thanks.
john_bry is offline   Reply With Quote
Old 11-16-2012, 06:02 AM   #2
DIY staff
Rewards Points: 7,174
It is not against code--so you should not be failed because of that---however---it looks amateurish and will put the inspector on alert--he will be looking for other funky work---I don't recommend you do that.
Old 11-16-2012, 06:18 AM   #3
Rewards Points: 1,214
Run neat and clean lines that are square with the environment , it looks much better and is easier to track later if there's a problem. Figure out how to get the hot on the left neatly and look Pro. Like oh'mike said the inspector will be looking closer. Plus Pride in workmanship means a lot.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-16-2012, 11:13 AM   #4
Special User
Rewards Points: 1,230
You can do it with two 45 fittings on each pipe to form an "X". 45 is way better than 90 as far as turbulence and pressure drop go, and I think they look nice too.
tylernt is offline   Reply With Quote
Old 11-16-2012, 11:23 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 352
Yep, run it square to the framing. If not the inspector will nit pick your work.
A couple more 90"s won't break the bank
Old 11-16-2012, 12:23 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 828
^^^That^^^^
The cleaner and neater the easy to see obvious stuff is...the less likely he will dig deeper.
But when they see hacks...even though it might be a good hack...it makes them wonder what else you did that is maybe not right...so they will go looking.
In the grand scheme of things....a couple of 90's are pretty cheap.
ddawg16 is online now   Reply With Quote
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 07:47 PM
Copper for Water Lines EveryTalk Plumbing 17 02-07-2012 11:29 PM
Angle valve on 1/2" copper tube for bathroom sink Bigb142 Plumbing 4 12-10-2011 09:24 AM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
