Hose Bib/sillcock Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2011, 11:31 AM   #1
Rewards Points: 97
Hose bib/sillcock leak
I have a hose bib on the side of my house and it's leaking. I tried to take it out so I can get the same one from the local hardware store. But wow! It won't come off! Maybe I'm not using enough force but I'm really afraid of snapping something behind the wall.
Is it usually soldered on? Or screwed on? The house was built in 1977.
Can I just get replacement parts? Like a new valve body or O-ring?
edta1 is offline   Reply With Quote
Old 05-23-2011, 02:02 PM   #2
Rewards Points: 1,596
From where is it leaking? Around the stem or out the spout? If the first, loosen the packing nut, wrap packing around stem, retighten nut. If the spout, you'll have to replace the washer.
Likely is soldered; I'd be real careful about twisting it any more unless you can verify that it is threaded.
Picture of valve would likely help.
bob22 is offline   Reply With Quote
Leak coming from air vent in ceiling when hose is on... callmedpit Plumbing 0 05-22-2011 09:16 PM
leak on blue part of washer where you connect your hose Dianah Appliances 3 05-12-2011 12:33 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
