Hose Bib Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2014, 04:48 PM   #1
Rewards Points: 866
Hose Bib Repair
I need to repair or replace an outside hose bib, which should be easy but I cannot get the bib off. It appears to have female threads screwed onto a threaded sleeve that should be sweated onto the copper coming from the house.
I am trying to avoid buying some MAP, solder, and flux and replacing the sleeve.
I am wondering if the bib was affixed to the sleeve so that the two cannot be taken apart.
The valve stem is not rebuildable. If I could get a valve stem or a new bib to rob the stem from I would do that and used the old body/ Any ideas? Do I simply have to get the MAP and remove the old sleeve and all?
Klawman is offline   Reply With Quote
Old 01-01-2014, 06:28 PM   #2
Rewards Points: 146
Agree. Sounds like a good idea. Try your idea of swapping out the stem from a new bib first.
By the looks of your pic, hose bib should unscrew from the female adapter/coupling. Sometimes they are soldered in like you said and are non-removable without unsoldering it, but I don't see any evidence of that. Maybe try some pb blaster, tap it a few times, let it set for awhile and try again using a big wrench on the hose bib and channel locks on the pipe coupling for equal pressure so you don't break the pipe.
It looks like copper pipe, so if it's soldered in and non-removable using wrenches, you can always just cut/deburr the pipe and throw a sharkbyte connector on it (male or female your choice, see pic for example), apply teflon tape/pipe dope on threads, screw on/tighten down your new bib, check for leaks, and done. No need to unsolder/solder anything. Just a thought. Others will be along shortly with more advice for you.
How's the weather in California? Looks sunny and warm in the pics. Really cold and snowy here right now in upstate NY.
Last edited by jmon; 01-02-2014 at 11:22 AM. Reason: added pic of a sharkbyte connector
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
Klawman (01-01-2014), oh'mike (01-01-2014)
Old 01-01-2014, 06:51 PM   #3
Rewards Points: 866
I hadn't thought of the shark bite. I just got back from Lowe's and they got me thinking about calling a plumber and be ready to pony up $150, buying the parts including a torch and all which would run me about $60. It is warm. The wife keeps running the AC. Not like where my son is returning at the end of the week for school in Kansas City.
Old 01-01-2014, 06:55 PM   #4
DIY staff
Rewards Points: 7,174
jmon sure does have a simple and quick solution----no burnt paint! Great thinking,
jmon (01-01-2014)
Old 01-01-2014, 07:15 PM   #5
Rewards Points: 6
Based on your pic, that's not a male fitting but a coupling. The hose bib was probably soldered to a short piece of pipe and joined to the house with the coupling. The Sharkbite is a good idea unless you have other plumbing jobs in your future.
Dan
djlandkpl is offline   Reply With Quote
Old 01-01-2014, 07:49 PM   #6
Rewards Points: 866
The absolute easiest solution may be to buy an identical bib and take the valve stem out of it to use in the old bib which can be left sweated on. That or the shark bite is nice and simple and simple I like.
The Following User Says Thank You to Klawman For This Useful Post:
jmon (01-01-2014)
Old 01-01-2014, 07:56 PM   #7
Rewards Points: 146
Yes, I agree, that would be the simplest fix, try that first. If that doesn't work for you, you have another back-up plan. Let us know how everything works out for you klawman. Thanks.
Old 01-02-2014, 08:04 PM   #8
Rewards Points: 866
It worked, I couldn't get the exact hose bibb but one from the same manufacturer was had at Lowe's. I robbed the valve stem and handle off of it, threaded it on the old valve with ample silicon grease for the rubber washer and Teflon tape for the thread and its a done deal for just over $8. A simple job at last! Best for the New Year to all.
The Following 2 Users Say Thank You to Klawman For This Useful Post:
jmon (01-02-2014), oh'mike (01-02-2014)
Old 01-02-2014, 09:17 PM   #9
Rewards Points: 146
And to you as well Klawman. Glad everything worked out for you. Sometimes we overlook the simplest things.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 01:51 PM
Sprinkler hose leaks LGF Gardening Forum 3 07-16-2011 01:35 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Submersible Pump Repair lorenzom Plumbing 10 09-17-2010 05:26 PM
