Hose Bib With Compression Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2009, 09:53 PM   #1
Rewards Points: 1,088
Hose Bib with compression fitting
Why are these hard to find?
handy man88 is offline   Reply With Quote
Old 06-16-2009, 07:08 AM   #2
rarely any room to tighten the fitting.
Old 06-16-2009, 10:13 AM   #3
Most hose bibb connections are not readily able to be seen. Compression fittings are required to be accessible (and seen) at all times.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-16-2009, 07:38 PM   #4
So are these usually screw on? If there's rarely any room to tighten, then that means there's rarely any room to solder either.
Old 06-16-2009, 10:13 PM   #5
Most are threaded. The frost free type are longer and have threads and/or sweat ends.
Old 06-17-2009, 12:03 AM   #6
Whoa...how do you unthread a faucet without running the risk of breaking the solder joint on the other end?
Is pipe dope usually used, or teflon tape?
Pex/Qest Compression Fitting Logback Plumbing 9 09-03-2010 10:32 PM
aluminum vs copper for compression fitting pnutzhome HVAC 7 03-19-2009 05:14 PM
compression fitting Barry J Plumbing 3 11-21-2008 12:19 PM
Installing a Compression Fitting squid226 Plumbing 3 10-10-2008 01:20 AM
compression fitting vs solder, block flame? nave Plumbing 9 01-25-2008 12:26 AM
