-   -   Hose Bib with compression fitting (http://www.diychatroom.com/f7/hose-bib-compression-fitting-46734/)
handy man88 06-15-2009 08:53 PM
Why are these hard to find?
Just Bill 06-16-2009 06:08 AM
rarely any room to tighten the fitting.
majakdragon 06-16-2009 09:13 AM
Most hose bibb connections are not readily able to be seen. Compression fittings are required to be accessible (and seen) at all times.
handy man88 06-16-2009 06:38 PM
So are these usually screw on? If there's rarely any room to tighten, then that means there's rarely any room to solder either.
majakdragon 06-16-2009 09:13 PM
Most are threaded. The frost free type are longer and have threads and/or sweat ends.
handy man88 06-16-2009 11:03 PM
Whoa...how do you unthread a faucet without running the risk of breaking the solder joint on the other end?
Is pipe dope usually used, or teflon tape?
