Hopw Do You Get Water To An Upper Heat Zone. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2012, 02:32 PM   #1
hopw do you get water to an upper heat zone.
I recently had to change my taco circulator pump and now can't get water in the upsatirs zone. When I open the drain valve, slightly, to get the air out and trun on the fill valve the water travels towards the boiler in stead of circulating through the line. Does someone know how to get the water to fill the upper zone, I am sure this is why I have no heat in the upper zone. I have one pump with auto shut valves to redirect the water.
mrebar457 is offline   Reply With Quote
Old 11-03-2012, 04:14 PM   #2
in water air rises so opening a drain valve which is at the bottom will just drain water out. are there any bleeders on the second floor? that is where you need to bleed the air out. if this is on a second floor you will need more then 10 pounds pressure to be able to force the air out of the system. you lose 5 pounds of pressure for each floor. once the air is out it will operate at under 10 pounds. most boilers have purge valves to bleed most of the air out. pictures would be most helpful.
The Following User Says Thank You to DannyT For This Useful Post:
GBrackins (11-03-2012)
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 01:56 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
