Hoping To Replace 30" Tub With 32"? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2010, 05:32 PM   #1
hoping to replace 30" tub with 32"?
Hi folks, I'd like to replace my 1950s 60 x 30 cast iron tub with a 60 x 32 acrylic one. (bigger selection of 32" tubs). My plumber's quote says "rerough plumbing" (we're ripping out the old tub, tile and shower/tub faucets and valve). My silly question is, is it going to cost extra for installation if we wanted to go with a 32" wide tub? I think he'd have to shift the drain about 1" to one side. We have sufficient floor space for the bigger tub.
Also bought a 3/4" valve, then heard it was overkill, but it is still usable, correct? (it is new and is compatible with the new shower/tub faucet).
Thanks in advance.
52ranch is offline   Reply With Quote
Old 11-01-2010, 08:29 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
"re-rough plumbing" is a broad term. Some is required for any tub replacement. Such as p trap, waste & overflow, valve, etc.
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Upgrade from 30" to 32" tub on slab? spidrw Kitchen & Bath Remodeling 3 01-19-2010 10:41 AM
To replace a door or to NOT replace a door Proulx06 Building & Construction 8 01-14-2007 10:41 AM
