Old 12-25-2011, 08:14 PM   #1
Hooking up dishwasher.
Basically trying to hook up a dishwasher. Want to know if that unused PVC pipe is a drain line or vent stack.
SoulJa is offline   Reply With Quote
Old 12-25-2011, 08:19 PM   #2
can't really tell from the angle of the picture...does it have auto vent screwed on.1st if it does its wrong should be verticial... 2nd you can cut this wrong pipe out install drain for dw and correct vent at same time...
Old 12-25-2011, 08:23 PM   #3
I understand none of what you said. I'm a carpenter. I stay away from plumbing. This is a close up.
Old 12-25-2011, 08:27 PM   #4
ok thats better ..not a auto vent ..looks like just a pluged off drain mybe clean out...should be able to drain dw there... how about close up of end of dw drain hose..
Old 12-25-2011, 08:27 PM   #5
A "Handy Husband"
rjniles's Avatar
Looks like a cleanout. Leave it be and install a DW tailpiece.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-25-2011, 08:30 PM   #6
on the left side it that a fitting below tee...looks like it..is it caped on other side facing wall????
Old 12-25-2011, 08:33 PM   #7
Uh first pic Ben? That I guess what your talking about is the braided supply like witha valve that runs through the cabinet to the dishwasher.
Old 12-25-2011, 08:36 PM   #8
no the black pipe on left side of drain,it has a tee going to other side then a fitting below it???? is it a another tee facing wall...
Old 12-25-2011, 08:39 PM   #9
Its 2 drains coming down from either sink going to a t. With a spacer in the middle ( i assume for a y fitting for dishwasher) Then to the trap with a cap on bottom to drain out. Then into the wall.
Old 12-25-2011, 08:44 PM   #10
is that a tee or a wye below the 1st tee....the opening would be facing the back wall feel with your hand ......it looks like a fitting you could attach dw to...
Old 12-25-2011, 08:48 PM   #11
Found this thing.
Old 12-25-2011, 08:52 PM   #12
Found this thing.
thats your connector for your d w ...hook on that your done.....make sure remove cap ..should be loop in drain line ...then clamp it to outlet....
Old 12-25-2011, 08:54 PM   #13
How do I remove cap?
Old 12-25-2011, 08:56 PM   #14
hard to tell from here ..just saw it off gentley.... with fine blade hacksaw.....still need to see a close up of the end of white hose comming from dw..
Old 12-25-2011, 08:58 PM   #15
:D here
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Final stages of Hooking up Dishwasher need advice K.M.G Plumbing 21 01-17-2011 11:28 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
