-   -   Hooking up dishwasher. (http://www.diychatroom.com/f7/hooking-up-dishwasher-127659/)
SoulJa 12-25-2011 08:14 PM
1 Attachment(s)
Basically trying to hook up a dishwasher. Want to know if that unused PVC pipe is a drain line or vent stack.
ben's plumbing 12-25-2011 08:19 PM
can't really tell from the angle of the picture...does it have auto vent screwed on.1st if it does its wrong should be verticial... 2nd you can cut this wrong pipe out install drain for dw and correct vent at same time...
SoulJa 12-25-2011 08:23 PM
1 Attachment(s)
I understand none of what you said. I'm a carpenter. I stay away from plumbing. This is a close up.
ben's plumbing 12-25-2011 08:27 PM
ok thats better ..not a auto vent ..looks like just a pluged off drain mybe clean out...should be able to drain dw there... how about close up of end of dw drain hose..
rjniles 12-25-2011 08:27 PM
Looks like a cleanout. Leave it be and install a DW tailpiece.
ben's plumbing 12-25-2011 08:30 PM
on the left side it that a fitting below tee...looks like it..is it caped on other side facing wall????
SoulJa 12-25-2011 08:33 PM
Uh first pic Ben? That I guess what your talking about is the braided supply like witha valve that runs through the cabinet to the dishwasher.
ben's plumbing 12-25-2011 08:36 PM
no the black pipe on left side of drain,it has a tee going to other side then a fitting below it???? is it a another tee facing wall...
SoulJa 12-25-2011 08:39 PM
Its 2 drains coming down from either sink going to a t. With a spacer in the middle ( i assume for a y fitting for dishwasher) Then to the trap with a cap on bottom to drain out. Then into the wall.
ben's plumbing 12-25-2011 08:44 PM
is that a tee or a wye below the 1st tee....the opening would be facing the back wall feel with your hand ......it looks like a fitting you could attach dw to...
SoulJa 12-25-2011 08:48 PM
1 Attachment(s)
Found this thing.
ben's plumbing 12-25-2011 08:52 PM
Originally Posted by SoulJa (Post 802956)
Found this thing.
thats your connector for your d w ...hook on that your done.....make sure remove cap ..should be loop in drain line ...then clamp it to outlet....:thumbup:
SoulJa 12-25-2011 08:54 PM
How do I remove cap?
ben's plumbing 12-25-2011 08:56 PM
hard to tell from here ..just saw it off gentley.... with fine blade hacksaw.....still need to see a close up of the end of white hose comming from dw..
SoulJa 12-25-2011 08:58 PM
1 Attachment(s)
:D here
