Hooking New Bath Into Sewer Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2008, 09:36 PM   #1
Hooking New Bath into Sewer Pipe
I am installing a new half bath in my basement. It is directly below my main floor bath (1 bathroom house), which is the main vent stack. I am going to be running the toilet drain into the main sewer drain, right near the main stack.
My question is, what is the code as far as distance from the main stack that I can "Y" into the main sewer drain? I have heard 10 pipe diameters from the base of the main stack. If this is correct, is it 10 stack pipe diameters, or 10 sewere pipe diameters? My stack is 3" cast iron pipe, and my main sewer pipe is 4" cast iron pipe. If this is not correct, what is the proper distance?
I hope that explains it enough. If not, let me know. TIA for any input.
BTW, my city has adoped the 2000 Michigan plumbing code.
Jason
jasoncw is offline   Reply With Quote
Old 02-26-2008, 10:03 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
UPC code does not specify, so as close as you wish, no set distance.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-26-2008, 10:07 PM   #3
Well, that's good to hear. Thanks for the quick reply.
Old 03-04-2008, 05:17 PM   #4
Just to follow up, I did contact the city, and I'm not sure if it is a MI requirement, or a city requirement, but the inspector told me a minimum 10 pipe diameters (of the stack pipe) from the stack.
Old 03-04-2008, 05:42 PM   #5
Journeyman Plumber
Then do as they say.
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Frozen Septic Sewer Pipe. econdave Plumbing 11 03-15-2008 06:00 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 08:29 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
