Home Run System Using Copper Insted Of Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 12:56 AM   #16
Rewards Points: 616
i agree with pex with viega press even for residential fire suppression (for the fire fighter side of you)
http://www.viega.net/xchg/en-us/hs.xsl/5208.htm
since you said cost is not a factor
but this is not what he is asking for so to help i would not recommend soft copper but hard copper instead of solder you have two options stab fitting (sharkbites or gator bites) which both are not plastic or the other and the best is propress
for fittings
http://www.viega.net/productcatalog.html#pg=U1
for tool which some small plumbing wholesaler rent
http://www.ridgid.com/Tools/Press-Tools/EN/index.htm
jaydevries is offline   Reply With Quote
Old 02-01-2012, 03:31 AM   #17
Well I actually wanted to use pex at the beginning but what turned me off was that I couldn't get a straight answer as far as what would be the best fitting ,witch I think would be the weak link on the system .....from the research I have done the expandable fittings would be the best of the best ????? What do you guys think
ogoz23 is offline   Reply With Quote
Old 02-01-2012, 01:28 PM   #18
Rewards Points: 616
i like viega fitting cost a little more but the pull test on fittings and the error proof cup system sold me
Old 02-01-2012, 01:54 PM   #19
Like jay said viega is in my opinion the better of the "pex" fittings manufacturer... You might want to check out this site http://www.similarsites.com/site/pexsupply.com
A list of pex supply companies... I prefer http://www.pexsupply.com/...
They have an excellent customer service and large supply of pex fitting to choose from... Hope this helps
dlwilson88 is offline   Reply With Quote
Old 02-01-2012, 02:02 PM   #20
I'm going to check it out now I'm between pex and rigid copper lol
Old 02-01-2012, 06:57 PM   #21
I learned to run PEX with the solid brass NIBCO barbed fittings and 1/8" stainless steel crimp rings. Barbed brass fittings go on the inside diameter and the crimp is tightened around the outside of the pipe onto the fitting. While not completely idiot-proof like the shark bites and other stab fittings they are insanely reliable.
Then again since you want to do home runs- the pricier jab fittings might be the way to go since you will only have a fitting at the fixture and your manifold. Jab fittings (at least the shark bites) have rubber o rings that make the seal- this might be a weak point years down the road when the rubber dries out but I've never heard of them failing.
PlumbDumb is offline   Reply With Quote
Old 02-01-2012, 08:11 PM   #22
Well I will be doing this project this weekend I will be taking pictures and try to share with his you guys..
The Following 2 Users Say Thank You to ogoz23 For This Useful Post:
PlumbDumb (02-02-2012), TheEplumber (02-01-2012)
Old 02-03-2012, 05:17 PM   #23
Which one did you decide to go with, the pex or copper?
Old 02-03-2012, 06:30 PM   #24
I'm doing copper
Old 02-03-2012, 07:48 PM   #25
Thumbs up
Good luck man, hope all goes well...
Old 02-03-2012, 08:28 PM   #26
Thanks will take pictures ill start at 8 am tomorrow
Old 02-03-2012, 08:49 PM   #27
Plumber
TheEplumber's Avatar
Rewards Points: 352
Better finish before the game. You're going to need a toilet during halftime.
The Following User Says Thank You to TheEplumber For This Useful Post:
PlumbDumb (02-05-2012)
Old 02-12-2012, 08:26 PM   #28
Well it didn't take 2 days it took the whole week!!!!@@!
The Following User Says Thank You to ogoz23 For This Useful Post:
TheEplumber (02-12-2012)
Old 02-14-2012, 04:06 PM   #29
Looks good!!!
Old 02-14-2012, 04:59 PM   #30
Rewards Points: 616
where does the hot water supply enter at besides that looks good as gold or copper
Reverse Osmosis system for home -- Costco "Watts" model dynamo Plumbing 2 12-28-2011 09:45 AM
DIY Home Security System (suggestions needed) tigerbalm2424 General DIY Discussions 10 06-13-2011 03:54 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
electrical requirements for large whole home system jumonji Electrical 6 02-23-2010 02:41 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
