Old 12-12-2010, 06:34 AM   #1
home hot water heating pipes
we have an older home that is heated with large ( 2 1/4 inch) pipes in the basement. I can not seem to find an insulation tube that is large enuff to do the job. What is the best way to insulate with the highest R value?
mweaver is offline   Reply With Quote
Old 12-12-2010, 06:49 AM   #2
You're most likely dealing with 2" steel pipe. You need 2" x 1" fiberglass insulation. It comes in 3' lengths. Look for a insulation company, as this won't be in the big box stores.
Work4living is offline   Reply With Quote
Decreased water pressure in home Gordon07 Plumbing 3 12-03-2009 12:44 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
