Holes In Sewage Pump Basin? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 01:13 PM   #1
holes in sewage pump basin?
I'm putting a sewage pump basin in my basement for a bathroom, it has a 4" waste inlet.
Upon excavating for the basin i found where our historical water problem in the basement is coming from. Water is entering the soil under the slab when it rains hard and eventually finds its way to above the slab.
What i would like to do is drill 1/4" holes around the side of the basin at a height between the top of the basin and the side inlet. My theory being that it will let the rainwater in but the waste should theoretically never get high enough to escape out through these holes.
bad idea?
marketbridge is offline   Reply With Quote
Old 09-05-2012, 01:26 PM   #2
Rewards Points: 13,694
Sure is a bad idea. May end up with sewer under the slab.
Better to have a sump pump pit just for the slab with a check valve leading outside.
Old 09-05-2012, 02:38 PM   #3
not a good idea. listen to joe
proper size sewage pump bergerdude Plumbing 3 08-15-2012 12:42 PM
water level equalizing in sump pump basin? dmp Plumbing 21 04-13-2012 06:42 PM
Sump Pump Basin install, existing rough sump hole. McSweny1103 Building & Construction 3 02-12-2012 02:45 PM
Sump Pump Basin jonathan123 Plumbing 2 08-21-2011 08:31 PM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 07:24 AM
