-   -   holes in sewage pump basin? (http://www.diychatroom.com/f7/holes-sewage-pump-basin-155933/)
marketbridge 09-05-2012 01:13 PM
I'm putting a sewage pump basin in my basement for a bathroom, it has a 4" waste inlet.
Upon excavating for the basin i found where our historical water problem in the basement is coming from. Water is entering the soil under the slab when it rains hard and eventually finds its way to above the slab.
What i would like to do is drill 1/4" holes around the side of the basin at a height between the top of the basin and the side inlet. My theory being that it will let the rainwater in but the waste should theoretically never get high enough to escape out through these holes.
bad idea?
joecaption 09-05-2012 01:26 PM
Sure is a bad idea. May end up with sewer under the slab.
Better to have a sump pump pit just for the slab with a check valve leading outside.
DannyT 09-05-2012 02:38 PM
not a good idea. listen to joe
