Old 02-05-2010, 11:10 PM   #1
Holes in flange dont match holes in toilet!
My father is installing a new toilet and has discovered that the holes in the toilet do not match with the holes in the flange. Has anyone else had this problem? What should be done to fix the problem. Thanks
ljenkins is offline   Reply With Quote
Old 02-06-2010, 01:48 AM   #2
Doing it myself
Alan's Avatar
Toilet flanges and the holes in the base of the bowl are standard. All are interchangeable. If they don't line up, then your flange isn't rotated properly with reference to the back wall behind the toilet.
I'd love to see a picture of this one.
Journeyman Plumber
Old 02-06-2010, 08:17 AM   #3
Did you guys install the flange or was it an existing flange?
If you just installed it that could be the trouble might not be lined up properly.
Was there an existing toilet there that was removed to install new?
SULTINI is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 02:22 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
