Hole In Slab Around Shower Drain... Fill It?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2013, 06:45 PM   #1
Hole in Slab Around Shower Drain... Fill it??
Hi all! My name is Christopher and this is my first post so let me know if I'm missing anything important.
The attached pictures are of the slab under my stand-up shower. I'm doing a remodel and when I removed the old preformed tub I found this hole.
I'm working to put in a tile shower with tiled floor. I'm going to use the Schluter Kerdi Shower System with the Kerdi Shower Tray. Makes sense to me that I must have some support under said tray.
A local contractor told me to get the plumbing ready for the tray and then backfill the hole with floor mud.
Is this the right way to do this? Also, is there a reason why the hole was left in the first place?
Thanks in advance!
Hole in Slab Around Shower Drain... Fill it??-img_3595.jpg   Hole in Slab Around Shower Drain... Fill it??-img_3596.jpg
creiteljorge is offline   Reply With Quote
Old 02-05-2013, 01:59 AM   #2
Rewards Points: 14,312
Anyone else think copper drain lines is a very bad idea.
Anytime I've seen it, it's leaking even when it's not in direct contact with concrete or soil.
Most often it's back filled with sand and a thin layer of concrete layed over it with some form of protection around the pipe where it goes through the concrete.
Old 02-05-2013, 06:16 AM   #3
DIY staff
Rewards Points: 7,174
Typically that is packed with gravel or sand---then covered with a thin skin of concrete or deck mud as the pan is installed---
You want some wiggle room when you install the pan----don't concrete that in before the pan is installed---the drain set goes below the floor level--so leave an open area to receive the drain set.
You may wish to change the P-trap and riser to PVC---most modern drain sets are not designed for copper.
ljfockler (02-05-2013)
Old 02-05-2013, 07:26 AM   #4
Thanks, guys.
So I could cut out the p-trap/riser and adapt to PVC at that point? I know the Kerdi System calls for a PVC drain but I was just going to adapt to PVC on the riser. Why would a PVC trap/riser be better?
I've heard mention of a 4" PVC "sleeve" that I could put around the riser for protection before I backfill. That way the entire drain pipe is not closely encased in sand/cement.
Old 02-05-2013, 07:44 AM   #5
DIY staff
So often the P-trap is corroded and will grab hair----so I always replace them---
The sleeve you are talking about is made of foam---yes they are handy---but if you leave that open--packed with sand---you will have some wiggle room-----just add a layer of deck mud as you are setting the pan/drain and you will still be able to adjust the drain enough for a good allignment with the drain set---
Old 02-05-2013, 09:09 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Looks like you have a 1.5" drain there. You need to change it to 2".
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
DidIDoThat (02-05-2013), oh'mike (02-05-2013)
Old 02-05-2013, 09:26 AM   #7
Roofmaster
Rewards Points: 2,210
At least the guys that poured your floor were nice enough to give you some working room there. Judging by the amount of copper oxide I see on your copper pipes, I agree with Joe. Go PVC DWV. Wheres the vent?
Old 02-05-2013, 09:29 AM   #8
Doing it myself
Alan's Avatar
Originally Posted by jagans View Post
Wheres the vent?
Judging by the angle of the pipe, and the crack in the slab, i'd guess it's just barely out of the picture there.
Journeyman Plumber
Old 02-05-2013, 10:55 AM   #9
Alan - I noticed some other posts mentioning that same thing regarding drain diameter. I will have to take a measurement of the drain pipe when I get home. I will update then.
The vent is about 3-4 feet outside of the picture in the direction that the pipe runs. As far as I can tell the vent is shared with the dual sinks. The bathroom only has one vent for sure.
oh'mike - So as long as the mud is still somewhat viscous I will be able to wiggle the drain while I'm setting the pan. The deck mud will still cure after it is covered up?
The Following User Says Thank You to creiteljorge For This Useful Post:
Old 02-05-2013, 05:43 PM   #10
Update - drain pipe is 1-1/2". There even used to be a standup shower there! Does this mean removing the drain back until it ties into a larger section of the drain system? I suppose it would be cutting a pretty big corner if I just adapted the Kerdi Drain to 1-1/2"...
Old 02-05-2013, 07:53 PM   #11
Doing it myself
Alan's Avatar
Yes, you're going to have to tie into a larger line somewhere. Not a bad idea anyway to get some of that copper out from under the slab.
Besides, you'll probably have a hard time adapting the 2" (more than likely abs or pvc) kerdi drain to 1-1/2" copper. The O.D. of the two materials is vastly different.
Besides all of that, once you get the shower built up, if you've got it plumbed with a 1-1/2" drain, you really won't be happy with it.
Journeyman Plumber
creiteljorge (02-06-2013), oh'mike (02-05-2013)
Old 02-05-2013, 09:26 PM   #12
DIY staff
The deck mud will cure fine under your pan----
Tags
drain , kerdi , slab
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
HELP ASAP Relocating Shower Drain In Slab - Drain Pipe Loose perryj Plumbing 5 08-20-2010 08:48 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
