Hole Size In Stud For DVW Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2011, 01:23 PM   #1
Rewards Points: 89
Hole size in stud for DVW pipe
What size arbor do I need to buy to install 1 1/4 inch PVC pipe in a stud.
It needs to run about 5 feet through 3 to 4 studs.
I assume that 1 1/4 inch won't work due to the pitch for the drain.Or am I wrong?
spring3100 is offline   Reply With Quote
Old 12-20-2011, 01:50 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
That would normally be a piece of 1 1/2" pipe that you tie a 1 1/4" trap into coming out of wall,is it for a bathroom sink?
The pipe size is going to be the inside diameter of the pipe,a 2" hole should be close for a piece of 1 1/2" pipe.
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
ben's plumbing (12-20-2011), spring3100 (12-20-2011)
Old 12-20-2011, 02:02 PM   #3
Rewards Points: 89
If that would be the case,not sure a 2 inch hole bored thru a 2 by 4 would leave much structural integrity.
The wall is non load bearing,so I guess its possible,and yes,it is a bathroom sink.
Old 12-20-2011, 02:18 PM   #4
plummen's Avatar
Ive seen a lot more taken out of 2x4s,not that i reccomend or would take 3" out of a load bearing wall ive seen people do some really stupid things over the years
A 2x4 is actually 1 1/2" x 3 1/2" so removing 2" from a non load bearing stud wall isnt that bad
Size of hole for 1/2" copper pipe through floor FirstAndTen Plumbing 13 09-05-2013 10:47 PM
Hole Saw Size The Force Tools 31 12-19-2011 01:39 AM
Pipe size question for supply side... Alvis Plumbing 4 02-16-2011 05:57 PM
Driving a hole into a stud handy man88 Carpentry 2 06-08-2008 10:28 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
