Holding Tank Blues - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2012, 10:10 AM   #1
holding tank blues
i recently bought a new H20w tank and when hooked up it failed to fill with water. I removed the "tee" and inside the tank inlet elbow I saw a piece of black plastic protruding down into the elbow. Seems as if it shouldn't be there. Is it a deflector or as I suspect, something that doesn't belong?
daddyjoe is offline   Reply With Quote
Old 09-29-2012, 12:30 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Can we assume you are talking about a water heater? In the nipple on top of the water heater are plastic inserts called heat traps (google "heat trap nipple"). They act like check valves to keep from losing heat due to convection currents. If you pipe the water heater backwards they will prevent the tank from filling.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-29-2012, 04:00 PM   #3
This is a water HOLDING/PRESSURE tank for a well-water system.
On looking more closely i see what appears to be a plug that MAY have been unintentionally left in the tank by the maker. It (the 'plug') has two 'prongs' which look like they need to be squeezed together and then the plug can be removed. I just wish to be sure before i go to yanking on something and causing damage .... Thanks, Joe
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Water holding tank leak Kcornell Plumbing 1 03-24-2012 07:46 PM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 12:33 PM
