Highrise Sink - Sewage Backup - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2012, 01:45 PM   #1
Highrise sink - sewage backup
I live in a highrise. The bathroom sink has water coming up through the drain with sewage and it will just pour out on its own.
The bathtub, toilet and kitchen sink drains all work fine.
Do you know what would be causing this and is this the buildings responsibility?
grex23 is offline   Reply With Quote
Old 04-23-2012, 03:04 PM   #2
Rewards Points: 13,694
Most likly just the trap under the sink is plugged up. Set a bucket under the drain and remove the trap.
Not the trap then use a snake to clean out the drain, I know you do not have one, try a metal coat hanger.
Old 04-23-2012, 03:41 PM   #3
If the trap is plugged up then how is sewage getting up thru the drain constantly? If the trap was plugged then nothing would be able to get thru the pipe at all. Nothing would be able to move up or down.
Instead everything is pushing up thru the pipes. Wouldn't that sound like a clog in the main drain line?
Old 04-23-2012, 03:48 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 664
If your mainline is clogged- chances are good that your tub and or toilet would also be backed up. Because only one fixture is affected it's safe to assume your problem is on the branch line serving that fixture. Start with the trap and tailpiece. If its clear, proceed to the trap arm and branch line.
The Following User Says Thank You to TheEplumber For This Useful Post:
Ravenworks (04-23-2012)
Old 04-23-2012, 04:10 PM   #5
Again: If there was a blockage in the Trap, then how would water be getting into the drain from outside. It keeps coming through and it is waste water.
A blockage of the trap would mean that all water being blocked would be coming from the SINK itself, waste would not be pushed upwards which is refilling, ie new waste.
I had the tub snaked awhile back so my guess is there is blockage inside the pipes itself that was pushed from the tub to the sink which is inbetween.
Will contact the building super.
http://www.sweethaven02.com/BldgConst/en51135a0017.gif
Old 04-23-2012, 04:42 PM   #6
Homerepairguy's Avatar
Rewards Points: 998
Do you have a washing machine in your apartment or condo? Or any other thing that can be higher than your bathroom sink?
In our home, the laundry tub and kitchen sink are on the same drain line. If that drain line clogs, water will backflow into the kitchen sink. Inevitably that happens when my wife does the laundry. Waste water from the washer flows into the laundry tub and the higher level backflows into the kitchen sink. This never affects our back-to-back bathrooms which are on a different drain line.
Just a possibility,
HRG
Homerepairguy is offline   Reply With Quote
Old 04-23-2012, 07:56 PM   #7
Just a possibility,
HRG
It can't be the sink trap because waste is going in the opposite direction on that pipe.
The super scheduled a water shutdown for tomorrow and I wonder if its related to issues someone else was having. But the water line is fine, it is the drain which is having issues.
Old 04-23-2012, 08:13 PM   #8
Rewards Points: 1,512
Could be waste water from a neighbor's sink that shares the same drain pipe for a few feet, and the blockage is in the shared part.
Old 04-23-2012, 08:24 PM   #9
Ill speak to the building super tomorrow. I had to shut the drain but even then some waste water is still spilling out into the sink.
It does appear the sink is on a different line than the other drain pipes.
Actually the upstairs neighbor wound up depressing the sink and I think they have a blockage cause my sink wound up pouring out water and now its fully full even though the sink was closed with particles and water.
Time to bring in the super and have him fix it. The line is definitely messed up.
Old 04-23-2012, 09:40 PM   #10
Rewards Points: 636
grex i agree not a trap issue i am going to say that the branch line is clogged on you floor below sink or floor below yours above their sink the branch line will need to be snaked at your sink down to floor below yours unless they are having back up issues also.i have seen this multiple times in a 6 story commercial building
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-23-2012, 10:46 PM   #11
Will contact the super tomorrow.
Old 04-24-2012, 06:20 PM   #12
Fixed. The maintanence guy had a special pump to fix it. Big metal manual pump. Didn't take so long to fix.
Im sure Im not the only person in highrises in the city with the problem. Common tool used in highrises in all likelyhood.
Old 04-24-2012, 06:50 PM   #13
Plumber
Rewards Points: 664
kinetic water ram?
Old 04-24-2012, 07:21 PM   #14
kinetic water ram?
Not the exact one but a similar device. Never even heard of these devices before. I guess in highrises they own these since I bet drain clogs are common.
Bright patent holders. It did the job. Drain goes down smoothly now. I filled up sink, drained it, it is all fine.
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Washer draining causing sewage to backup into bathtub SuzyQ is Me Plumbing 5 08-19-2011 03:11 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 12:14 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
