High Water,ct Bill Meriden - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2012, 08:09 PM   #1
high water,ct bill meriden
my water bill was 1000 3 months ago, then 500, then 1200, now 550. The meter was checked, no leaks, not much usage, just normal day to day. If a outside hose is on at the outside faucet but is turned off at the end of the hose nozzle so no water is exiting the hose, is the meter stilling charging for the water running?
SADONIS57 is offline   Reply With Quote
Old 09-08-2012, 07:32 AM   #2
Rewards Points: 1,514
1. The meter reader misread the meter. The billing should correct itself the next month, either up or down.
2. You have a leak or dripping faucet or running toilet somewhere. Observe the meter when "nobody is using water". If the spinner or fractional cubic foot indicator moves in a ten minute time span, then you have a leak.
... is the meter still charging for the water running ...
Yes unconditionally. If the water is not running then the meter is not charging. If the meter is charging then the water is running.
Old 09-08-2012, 07:57 AM   #3
biggles's Avatar
shut the valve to the toilet off... let it sit check it hourly seeing if the tank (not the bowl) drains out thru the flapper.1K in 3 months is a ton of water...
Old 09-08-2012, 12:11 PM   #4
Rewards Points: 6,652
Misread meter. Best way to find out, is look at the bill and see if it states Actual or Estimated for the past 12 months. Even better, call the utility that you buy water from and have them review the bill. You don't by chance of electronic meters on the homes in your area, or per chance just had your meters changed over to them recently.
High pressure operating Sdeclara HVAC 13 01-17-2012 02:44 PM
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 08:38 AM
How high is too high for washer drain jcpiebald Plumbing 5 12-30-2011 07:42 PM
High Def TV with ExpressVu fjacky Home Theater 3 12-18-2011 07:35 AM
High rise Plumbing question roach_779 Off Topic 8 01-17-2011 08:36 PM
