-   -   High TDS (http://www.diychatroom.com/f7/high-tds-169672/)
qitara 01-20-2013 10:08 PM
High TDS
Hi
I am having a problem with hard water, The water i am getting is around 2800TDS
I bought a RO system 7 stages but the water that i get from it is 500TDS
is there a way to lower this, extra filters maby ?
joecaption 01-20-2013 10:12 PM
Why would you not have used a water softner for this instead?
qitara 01-20-2013 10:18 PM
I need the RO system for drinking water
Akpsdvan 01-20-2013 11:37 PM
An RO system will lower the TDS by 90% depending on the quality of equipment.
Starting with 2800TDS and getting to 500TDS is not bad, but if you are looking for 0 you will need to either up grade to a light commercial unit that can take the that is sized for your set up with pumps or go with another ro system to use the treated and treat it again to get it close to the 0.
It is not an answer to say for drinking, that is the main use for the RO, but what is up with the high starting tds..
Is that tds salt ? sea water?
quanchai 01-21-2013 11:31 AM
If i got an extra membrane and connected it in series with the other one (Total 2) would that get the TDS down ?
TDS salt
