I have very high pressure water coming into my house (160 psi) from the County. I have a pressure reducer so my water pressure at the faucets and tub etc is around 55 psi. I was told that was normal. I also have a small expansion tank (about double the size of a football) near the hot water heater. The problem is that sometimes I turn on one of the faucets and I get a high pressure surge of water before it levels off to normal. It happens sporadically all over the house. It doesn't happen all the time and I can't find a pattern either. I was thinking that my pressure reducer is going bad and letting the pressure build up or maybe my expansion tank is too small or gone bad...or both. Any ideas?
It very well could be the PRV, but what I really want ot know is what was the expansion tank pressure pumped up to, use a tire pressure gage at test it on the top of the tank, let us know what it reads.
The expansion tank pressure is too low, if the house is at 55 and the tank is at 45, then the tank is not going to work, the tank need to be set higher then the house pressure, so when hot water expands it will allow water to enter the tank when the pressure on the system reaches the pressure, right now the tank is probably full and no place for water to expand into when required. I'd pump up the tank to a good 65psi.
Ok great. I'll try that and see if it will fix the problem. If not, I guess that only leaves the PRV. Thanks for the help!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
