High Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2007, 03:53 PM   #1
High pressure
The house is on city water which normal pressure 50 psi. This is a new hook up, one year ago. When home is left for the weekend there is high pressure built up 125 psi. Once a valve is turn on all back to normal pressure. Some one told us there could have been a check valve put on by the city or on the city meter and the hot water tank now builds high pressure. Is this true? What's the correct fix? bjr23
bjr23 is offline   Reply With Quote
Old 03-27-2007, 07:24 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
There could be a check valve somewhere, or PRV valve thats not working correctly. If so find it replace it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 11:11 AM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Help me understand my well... Alan Plumbing 5 09-04-2006 07:01 PM
